Best of Congress 2020: Wireless Sensor Measurement in 3D Printed Sand Molds
Additive manufacturing is enabling the casting of complex geometries directly from digital design data and including 3D-scanned and reversed-engineered structures and even functionally-graded lattices. By inkjetting binder into a bed of sand layer-by-layer, dimensionally-precise sand molds and cores can be printed to serve as soft tooling for sand casting. However,... more
Additive manufacturing is enabling the casting of complex geometries directly from digital design data and including 3D-scanned and reversed-engineered structures and even functionally-graded lattices. By inkjetting binder into a bed of sand layer-by-layer, dimensionally-precise sand molds and cores can be printed to serve as soft tooling for sand casting. However, the related increase in geometry complexity can lead to challenges in ensuring casting quality and yield. One recently-explored remedy is to introduce sensors (the Internet of Things) to enable the collection of a diversity of data at difficult-to-access locations in molds and includes measuring temperature, pressure, moisture, and detecting core shift. This webinar will describe work in wirelessly measuring temperature, humidity, magnetic field, metal velocity, and most recently, in barometric pressure, to monitor the pressures that accumulate within cores due to binder decomposition. less
