Demonstration of the Impact of Thermomagnetic Processing on Cast Aluminum Alloys
A number of alloys were processed via thermomagnetic processing (TMP) including 242, 355, and Al-8Ce-10Mg alloys. Mechanical property results from cast tensile samples heat treated in ORNL?s 5-inch superconducting magnet system clearly indicate a 10 to 65% increase in yield strength (YS) and 16 to 37% increase in ultimate tensile... more
A number of alloys were processed via thermomagnetic processing (TMP) including 242, 355, and Al-8Ce-10Mg alloys. Mechanical property results from cast tensile samples heat treated in ORNL?s 5-inch superconducting magnet system clearly indicate a 10 to 65% increase in yield strength (YS) and 16 to 37% increase in ultimate tensile strength (UTS) over reported conventional heat treatment practice values depending on the alloys system. less
