• Finite Element Analysis of Low-Alloy steel Castings
    Do you need to determine if a low-alloy steel casting is adequately designed for an anticipated duty cycle? Hear how proper FEA drives important engineering decisions for your low-alloy steel castings. Patrick Severson of Komatsu will outline key steps to constructing a proper finite element model you can use for... more
