Investigating the Effects of Turbulent Gating on C89833 Material
Brass foundries have typically seen an increase in scrap rates due to castings failing leak testing since the conversion from leaded brass alloys to no-lead brass alloys. In most cases, foundries have not made significant changes to the gating systems to address this issue with the no-lead alloys. While turbulent gating systems may not have been associated with scrap issues with leaded alloys, they may be contributing to the struggles of making pressure-tight no-lead castings. This is an investigation of the effect that turbulent gating systems have on the C89833 low-lead brass alloy.
Greenhouse Gas Accounting for Foundry Part 1: Intro, Methodology & Reduction
Cast-In Inserts in Aluminum Compound Castings
Policy Issues Affecting Metalcasters
Heat Treatments to Develop High-Strength Ferritic Ductile Iron
Progress after Covid: 2021 BLS Foundry Safety Trends
Proposed Changes by OSHA, California & Washington State to the Federal Lead Rule & Impact on Foundries
