VideoMember Only00:10:11 May 19, 2023The Effect of Cooling Rate on the Microstructure and Physical Properties of Hypereutectic Al-Ce Alloys READ MORE ADD TO CART
VideoMember Only00:08:37 May 18, 2023Remanufacturing of Military Castings on the Battlefield READ MORE ADD TO CART
VideoMember Only00:10:08 May 18, 2023Effects of Casting Defects on Distortion in High Intensity Quench Systems’ READ MORE ADD TO CART
VideoMember Only00:10:25 May 18, 2023Analysis of Next Generation Bearing Steels READ MORE ADD TO CART
VideoMember Only00:08:32 May 18, 2023Loss of Kinetic Zone Pressure Causes Mold Wall Collapse During Filling Across a Glue Joint in Lost Foam Casting READ MORE ADD TO CART
VideoMember Only00:14:47 May 18, 2023Monitoring Curing Effectiveness of Chemically Bonded Sand Molds using Embedded Sensors READ MORE ADD TO CART
VideoMember Only00:05:15 May 15, 20233D Printed Sand Molds Using Selective Powder Deposition READ MORE ADD TO CART
VideoMember Only00:05:19 May 15, 2023Towards a Fully Recycled Aluminum Alloy for Automotive Applications READ MORE ADD TO CART
VideoMember Only00:10:50 May 15, 2023Design and Construction of a Testing Apparatus for Measuring Multi-Axial Wall Movement During SGI Solidification READ MORE ADD TO CART
