Why Lost Foam?
The webinar explains the steps of the Lost Foam Casting (LFC) process and shares examples of project successes derived through LFC. We cover which countries are using the Lost Foam process and how prevailing it is on the global scene. You also learn the type of parts Lost Foam is... more
The webinar explains the steps of the Lost Foam Casting (LFC) process and shares examples of project successes derived through LFC. We cover which countries are using the Lost Foam process and how prevailing it is on the global scene. You also learn the type of parts Lost Foam is best for and review the benefits of using this method. For each limitation identified for the process, we also identify remedies being developed through AFS research. less
